Api session event editor netcluster
Revision as of 14:52, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetcluster/
API Endpoints for Net Cluster editing.
Name Description
add Add new Net Cluster
remove Remove existing Net Cluster
set_name Set the name of a Net Cluster
Additional API Endpoints:
Name Description
add_loads_in_area_to_net_cluster Add unclustered Net Loads to a Net Cluster given a MultiPolygon
generate_clusters Generate Net Clusters for a set of Net Types, using a Clustering Type, a Region, allowed owners of Buildings, cluster area size, default Stakeholder for created Net Clusters. A default Stakeholder for Net Loads without an associated Building. A Cluster Attribute and optional specific value can be used to only include specific Net Loads. Optionally, Net Loads identified as Collective can be clustered separately
remove_all_clusters Remove all Net Clusters with Net Loads belonging only to a particular Net Type
remove_loads_in_area_from_net_cluster Remove Net Loads from a Net Cluster given a MultiPolygon
remove_network Remove a Network of a particular Net Type, with the option to keep the Root Load
set_fraction_connected Set the fraction with Net Loads of this Cluster that are set to connected
set_owner Set the owner of a Net Cluster
set_scenario Set the Scenario in which this Net Cluster is active
