Api session event editor measure add terrain
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/add_terrain/
Description: Add a new Terrain Spatial to a Measure
0 REQUIRED (MEASURE Integer ID) Measure
200 Integer (Terrain Spatial ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_terrain/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_terrain/", options)
