Api session event editor indicator remove stakeholder
API Endpoint: api/session/event/editorindicator/remove_stakeholder/
Description: Remove the association to a particular Stakeholder from an Indicator
| 0 | REQUIRED | (INDICATOR Integer ID) | Indicator |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorindicator/remove_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorindicator/remove_stakeholder/", options)
