Api session event editor geotiff add ascii url
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeotiff/add_ascii_url/
Description: Add new GeoTIFF Item from Web ASCII URL
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) GeoTIFF Names
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Web ASCII URLs
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Uploaders
3 REQUIRED (String or multiple values in array ["a", "b", "c"]) CRSs
200 Integer[] (GeoTIFF IDs)
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name 1", "Web ASCII URL 1", "Uploader 1", "CRS 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "GeoTIFF Name 1", "GeoTIFF Name 2", "GeoTIFF Name 3" ], [ "Web ASCII URL 1", "Web ASCII URL 2", "Web ASCII URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ], [ "CRS 1", "CRS 2", "CRS 3" ] ]'
JavaScript example POST
 body: '[ "GeoTIFF Name 1", "Web ASCII URL 1", "Uploader 1", "CRS 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii_url/", options)
