Api session event editor chat set instructions
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorchat/set_instructions/
Description: Set the instructions of a Chat Channel
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) Chat Channels
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Instructions
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorchat/set_instructions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Instruction 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchat/set_instructions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Instruction 1", "Instruction 2", "Instruction 3" ] ]'
JavaScript example POST
 body: '[ 1, "Instruction 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/set_instructions/", options)
