Key (Sight Distance Overlay)
Revision as of 13:29, 11 November 2026 by Frank@tygron.nl (talk | contribs)
  • If the distance is 0, the Item is excluded from line-of-sight calculations.
  • Negative values are not allowed. If a negative distance value is used, it is considered 0.
  • When using the Api session event editor overlay set key value endpoint, this attribute can be set for a Sight Distance Overlay using the default key KEY.
API Endpoints
