Api session event editor panel add template
API Endpoint: api/session/event/editorpanel/add_template/
Description: Add a Template Excel Panel using a Panel Template. Also adds a new Overlay when associated.
| 0 | REQUIRED | (Enumeration) | Panel Template | DANGEROUS_OBJECTS, NETWORK_INTERACTION, TRAFFIC_NOISE, WATER_AREAS or WEIRS |
| 200 | Integer (Template Panel ID) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_template/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TRAFFIC_NOISE"'JavaScript example POST
body: '"TRAFFIC_NOISE"'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add_template/", options)
