Api session event editor panel set answer contents
Revision as of 08:36, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/set_answer_contents/
Description: Set the text content of an an Answer of a Panel
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Integer number) Answer ID
2 REQUIRED (String) Text
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_answer_contents/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text" ]'
JavaScript example POST
 body: '[ 1, 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_answer_contents/", options)
