Api session event editor setting set region
API Endpoint: api/session/event/editorsetting/set_region/
Description: Set the Region of a Project
| 0 | REQUIRED | (Enumeration) | Region | AFRICA, ASIA, NORTH_AMERICA, NORTHWESTERN_EUROPE or OTHER |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_region/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"NORTH_AMERICA"'JavaScript example POST
body: '"NORTH_AMERICA"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_region/", options)
