Api session event logic cinematic reached point
Revision as of 15:48, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/cinematic_reached_point/
Description: Notify a Key Point is reached for a Cinematic.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Data
2 REQUIRED (Integer number) Key Point ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_reached_point/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_reached_point/", options)
