Api session event editor global set visualisation name
Revision as of 15:47, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorglobal/set_visualisation_name/
Description: Set the name of a Global shown in the 3D Visualization
0 REQUIRED (GLOBAL Integer ID) Global
1 REQUIRED (String) Name
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_visualisation_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name" ]'
JavaScript example POST
 body: '[ 1, "Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_visualisation_name/", options)
