Api session items settings
Revision as of 15:33, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/settings/
Edit items with events described at Api session event editor setting.
Default Query:
https://engine.tygron.com/api/session/items/settings/?token=API_TOKEN
Example Response:
  "id" : 0,
  "value" : "GR_ATTR",
  "version" : 1
  "id" : 1,
  "value" : "0",
  "version" : 76
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/settings/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/settings/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/settings/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/settings/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/settings/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/settings/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/settings/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/settings/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/settings/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/settings/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/settings/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/settings/?f=ZIPSMILE&token=API_TOKEN
Api Model Setting
API Model description of Setting
Name Type Description
id int
value String
version int
