Api session event participant stakeholder set location
API Endpoint: api/session/event/participant/stakeholder_set_location/
Description: Stakeholder's view is moved to the location in the 3D Visualization.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point | |
| 2 | REQUIRED | (true, false) | Ping others (show them my location) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658791.4055938431, 6799368.671581409 ]
}, true ]
'Curl example multi item POST
[ 1, {
"type" : "Point",
"coordinates" : [ 658794.6522418947, 6799404.496442046 ]
}, true ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658791.4055938431, 6799368.671581409 ]}, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857", options)
