Api session event logic stakeholder select
API Endpoint: api/session/event/logic/stakeholder_select/
Description: Select the preferred Stakeholder or the next available option if unavailable.
| 0 | REQUIRED | (Integer number) | Preferred Stakeholder or empty | |
| 1 | REQUIRED | (String) | Client Token (from Join Session event) |
| 200 | Integer (Selected Stakeholder ID) |
curl 'https://engine.tygron.com/api/session/event/logic/stakeholder_select/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Client Token" ]'JavaScript example POST
body: '[ 1, "Client Token" ]'
fetch("https://engine.tygron.com/api/session/event/logic/stakeholder_select/", options)
