Api session event logic cinematic stakeholder stop
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/cinematic_stakeholder_stop/
Description: Stop a playing Cinematic for a Stakeholder.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_stop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_stop/", options)
