Api session event editor zoning add
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorzoning/add/
Description: Add a new Zone, optionally as Category Zone
0 REQUIRED (true, false) As Category Zone true or false
200 Integer (Zone ID)
curl 'https://engine.tygron.com/api/session/event/editorzoning/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
JavaScript example POST
 body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorzoning/add/", options)
