Api session event editor weather set duration
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorweather/set_duration/
Description: Set the duration of the Weather's visualization.
0 REQUIRED (WEATHER Integer ID) Weather
1 REQUIRED (Floating point number) Duration of visualization in seconds
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 66 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 4 ]'
JavaScript example POST
 body: '[ 1, 66 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_duration/", options)
