Api session event editor trigger add
API Endpoint: api/session/event/editortrigger/add/
Description: Add a new Trigger with a particular Timing
| 0 | OPTIONAL | (Timing or multiple values in array [a, b, c]) | Timing |
| 200 | Integer[] (Trigger ID) |
curl 'https://engine.tygron.com/api/session/event/editortrigger/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''JavaScript example POST
body: ''
fetch("https://engine.tygron.com/api/session/event/editortrigger/add/", options)
