Api session event editor setting set decimals
Revision as of 15:31, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/set_decimals/
Description: Set how many decimal places Attributes are allowed to have.
0 REQUIRED (Integer number) Number of decimal places
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_decimals/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_decimals/", options)
