Api session event editor scenario add measure
Revision as of 15:31, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorscenario/add_measure/
Description: Add a Measure that is Triggered on Scenario activation.
0 REQUIRED (SCENARIO Integer ID) Scenario
1 REQUIRED (MEASURE Integer ID) Measure
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/add_measure/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/add_measure/", options)
