Api session event editor plot add
API Endpoint: api/session/event/editorplot/add/
Description: Add a new Plot with an owner
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder (owner) |
| 200 | Integer (Plot ID) |
curl 'https://engine.tygron.com/api/session/event/editorplot/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorplot/add/", options)
