Api session event editor parametric set alignment
Revision as of 15:31, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorparametric/set_alignment/
Description: Set the alignment of a Parametric Design.
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple integer values in array [1, 2, 3]) Parametric Designs
1 REQUIRED (Alignment or multiple values in array [a, b, c]) Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_alignment/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ROAD" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_alignment/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "ROAD", "SPACED", "SPACED" ] ]'
JavaScript example POST
 body: '[ 1, "ROAD" ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/set_alignment/", options)
