Api session event editor panel remove global
Revision as of 15:31, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/remove_global/
Description: Remove Globals from a Global Panel
0 REQUIRED (PANEL Integer ID) Global Panel
1 REQUIRED (GLOBAL Integer ID or multiple integer values in array [1, 2, 3]) Globals
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_global/", options)
