Api session event editor panel remove answer
Revision as of 15:31, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/remove_answer/
Description: Remove an Answer (Panel) from a Panel
0 REQUIRED (PANEL Integer ID or multiple integer values in array [1, 2, 3]) Panels
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Answer (Panel) IDs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_answer/", options)
