Api session event editor panel add
Revision as of 15:31, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/add/
Description: Add a Panel of a particular Type
0 REQUIRED (Enumeration) Panel Type EXCEL_PANEL, GLOBAL_PANEL, TEMPLATE_EXCEL_PANEL, TEMPLATE_TEXT_PANEL, TEXT_PANEL or WEB_PANEL
200 Integer (Panel ID)
curl 'https://engine.tygron.com/api/session/event/editorpanel/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"GLOBAL_PANEL"'
JavaScript example POST
 body: '"GLOBAL_PANEL"'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add/", options)
