Api session event editor netload add and set node
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/add_and_set_node/
Description: Add a new Net Node for a Point and assign it to a Net Load
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658750.1882680535, 6799413.299202037 ]
Curl example multi item POST
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658758.4015242801, 6799308.374823827 ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658750.1882680535, 6799413.299202037 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
