Api session event editor netcluster
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetcluster/
API Endpoints for Net Cluster editing.
Name Description
add Add new Net Cluster
remove Remove existing Net Cluster
set_name Set the name of a Net Cluster
Additional API Endpoints:
Name Description
add_loads_in_area_to_net_cluster Add unclustered Net Loads to a Net Cluster given a MultiPolygon.
generate_clusters Generate Net Clusters for a set of Net Types, using a Clustering Type, a Region, allowed owners of Buildings, cluster area size, default Stakeholder for created Net Clusters. A default Stakeholder for Net Loads without an associated Building.A Cluster Attribute and optional specific value can be used to only include specific Net Loads. Optionally, Net Loads identified as Collective can be clustered separately.
remove_all_clusters Remove all Net Clusters with Net Loads belonging only to a particular Net Type.
remove_loads_in_area_from_net_cluster Remove Net Loads from a Net Cluster given a MultiPolygon.
remove_network Remove a Network of a particular Net Type, with the option to keep the Root Load.
set_fraction_connected Set the fraction with Net Loads of this Cluster that are set to connected.
set_owner Set the owner of a Net Cluster
set_scenario Set the Scenario in which this Net Cluster is active
