Api session event editor levee set angle degrees
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorlevee/set_angle_degrees/
Description: Set the slope angle of a Levee
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (Floating point number) Angle in Degrees
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 76 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 19 ]'
JavaScript example POST
 body: '[ 1, 76 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/", options)
