Api session event editor indicator set active
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorindicator/set_active/
Description: Set whether an Indicator is active (recalculated and visible to Stakeholders).
0 REQUIRED (INDICATOR Integer ID or multiple integer values in array [1, 2, 3]) Indicators
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Active Array
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_active/", options)
