Api session event editor global add query
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorglobal/add_query/
Description: Add a new Global with a TQL Query
0 REQUIRED (String) TQL Query
200 Integer (Global)
curl 'https://engine.tygron.com/api/session/event/editorglobal/add_query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query"'
JavaScript example POST
 body: '"TQL Query"'
fetch("https://engine.tygron.com/api/session/event/editorglobal/add_query/", options)
