Api session event editor geotiff export
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeotiff/export/
Description: Export a GeoTIFF as a byte array. For files larger than 2GB, use the Stream API.
0 REQUIRED (GEO_TIFF Integer ID) GeoTIFF
200 byte[] (Byte array)
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/export/", options)
