Api session event editor geooption set number
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeooption/set_number/
Description: Set the value of a Geo Option to a numeric value
0 REQUIRED (Enumeration) Geo Option Type AGRICULTURE, BAG3D_GEOMETRIES, DTM_DSM_THRESHOLDS, HEIGHTMAP_RESOLUTION, I3S_GEOMETRIES, IMWA, INTEREST_AREA_MARGIN, NL_AHN, NL_BGT, NL_ENERGY_LABEL, NL_MAX_TREE_HEIGHT, NL_MIN_TREE_HEIGHT, NL_TRAFFIC_INFOMIL, NL_TRAFFIC_INWEVA, NL_TRAFFIC_NSL, NL_TRAFFIC_NSL_CONVERSION, OSM_BUILDINGS, OSM_LANDUSE, OSM_NEIGHBORHOODS, OSM_ROADS, OWNERSHIP, SATELLITE_RESOLUTION, TREES, UNDERGROUND, WATER or WORLD_WATER
1 REQUIRED (Floating point number) Numeric Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeooption/set_number/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "NL_BGT", 43 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeooption/set_number/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "NL_BGT", 1 ]'
JavaScript example POST
 body: '[ "NL_BGT", 43 ]'
fetch("https://engine.tygron.com/api/session/event/editorgeooption/set_number/", options)
