Api session event editor excelsheet add matrix
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorexcelsheet/add_matrix/
Description: Add new Excel Sheet based on matrix (rows and columns) containing the values and formulas for each cell and a second with optional labels.
0 REQUIRED (String) Name
1 REQUIRED (Object or multiple values in array [a, b, c]) Matrix containing content (numeric value, text or formula starting with =) for each cell.
2 REQUIRED (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) Matrix containing labels for each cell, may be empty.
3 REQUIRED (String) Uploader Name
200 Integer (Excel Sheet ID)
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add_matrix/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", [ 1, "TEXT" ], [ "A1", "B1" ], "Uploader Name" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add_matrix/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", [ [ 1, "TEXT" ], [ 3, "TEXT" ], [ 5, "TEXT" ] ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ], "Uploader Name" ]'
JavaScript example POST
 body: '[ "Name", [ 1, "TEXT" ], [ "A1", "B1" ], "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/add_matrix/", options)
