Api session event editor area set relation
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/set_relation/
Description: Set an Area Relation to an Item ID
0 REQUIRED (AREA Integer ID) Area
1 REQUIRED (Enumeration) Relation BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, CONTENT, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER
2 REQUIRED (Integer number) Item ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/set_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OWNER", 1 ]'
JavaScript example POST
 body: '[ 1, "OWNER", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/set_relation/", options)
