Api session event editor area generate water areas
API Endpoint: api/session/event/editorarea/generate_water_areas/
Description: Generate Water Level Area(s) with the Water Level Attribute set to the provided value
| 0 | REQUIRED | (Floating point number) | Water Level (m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '67'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '17'JavaScript example POST
body: '67'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
