Api session event editor address set addition
API Endpoint: api/session/event/editoraddress/set_addition/
Description: Set the addition of an Address
| 0 | REQUIRED | (ADDRESSE Integer ID or multiple integer values in array [1, 2, 3]) | Addresses | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Addition |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_addition/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Addition 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_addition/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Addition 1", "Addition 2", "Addition 3" ] ]'JavaScript example POST
body: '[ 1, "Addition 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_addition/", options)
