Api session event editor overlay add difference entry
API Endpoint: api/session/event/editoroverlay/add_difference_entry/
Description: Add an entry to the difference legend a specified Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Overlay ID | |
| 1 | OPTIONAL | (String or multiple values in array ["a", "b", "c"]) | Name (optional) | |
| 2 | OPTIONAL | (TColor or multiple values in array [a, b, c]) | Color (optional) | |
| 3 | OPTIONAL | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Value (optional) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/", options)
