How to add the Travel Distance Overlay
Below an example with the Travel distance overlay based on a school and the travel distance for pedestrian traffic. We want to visualise which houses (and other buildings), within a range of 20m to a connecting sidewalk, are within a walking distance of 500m from a certain school.
Setting up the overlay
| 1 | From the Current Situation tab, add a Travel Distance Overlay from the category Distance. Adjust the grid as desired, 1 meter will give a nice resolution in our example. | ![]() |
| 2 | Go to the Attributes tab of the Travel Distance Overlay. The Fill distance is set by default on 20m and the Travel distance on 500. Set the Route cars on 0 to not include roads for car traffic. Set the Route pedestrians on 1 to include roads for pedestrian traffic. | |
| 3 | On the Keys tab of the overlay, on the right side of the editor, the defaults keys DESTINATION_AREA and BLOCKED are already filled in. You can change a key to another attribute, such as 'FOO', by selecting it from the drop-down menu for each key. For this how to this is not necessary. | ![]() |
| 4 | Draw an area over the school of which you want to calculate the travel distance from. Add the corresponding key as an attribute to the area. In this example add the attribute ROUTING_AREA with a value of 1 to the area. | |
| 5 | Update the Travel Distance Overlay if Auto-update is off. |
