How to edit the attribute information of an address
Revision as of 13:14, 8 October 2026 by Frank@tygron.nl (talk | contribs)
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar)
How to add an attribute:
  1. Select the building that you want to edit.
  2. Go to the right panel and press Attributes.
  3. In the building detail panel, select a building or address in the choice box.
  4. Select the intended attribute and edit as desired.
Example of adjusting the attribute information of an address
