How to edit an action menu
Revision as of 13:11, 8 October 2026 by Frank@tygron.nl (talk | contribs)
How to edit an action menu:
  1. Click on the Future design tab in the editor ribbon bar.
  2. Hover over and select Actions,
  3. Click on the name field in the detail panel to change the name of this action menu.
Editor → Future Design (Ribbon tab) → Actions (Ribbon bar) → The Action Menu to edit (Left panel)
The right panel in the editor, when editing Action Menus.
When you select an Action Menu, the right panel will automatically be filled with the information pertaining to that menu. A number of properties pertaining to a menu can be edited.
Name
The field for the "name".
This field is for the name of the menu. The menu name is displayed when a user hovers the mouse over a menu. You can change the name of the menu by editing the textfield.
Icon
The menu's "image".
The Menu image is a visual representation of a menu. The menu image represents a group of actions. You can change the image by clicking the Menu image and choosing an image from the list of images that appears.
Active
The "active" checkbox.
The "Active" property dictates whether the Action Menu is activated at the start of the project. You can change this by checking or unchecking the checkbox
Stakeholders
The checkboxes for giving stakeholders access to the Action Menu.
Stakeholders with whom the Action Menu is shared have access to the actions in the menu. In addition, this sharing can be defined by level, meaning that the availability of an Action Menu can change by stakeholder and by level. To grant access, locate the desired level and stakeholder in the list, then check the corresponding checkbox.
