AI Agent
An AI Agent within Tygron Platform that perceives its environment, processes information, and acts to achieve specific goals. It works autonomously to complete assigned tasks effectively.
Components
Each Tygron AI Agent has four main components:
Persona
Each agent has a defined role, style, attributes and instructions. These help it behave consistently while adapting through interaction.
Memory
Memory helps Agents maintain context and adapt over time. Short memory is stored inside a cache, longer memory is stored in the history via e.g. Chat Messages or via additional "job descriptions" named Skills.
Tools
Tools are external functions or resources that Agents use to find information, edit Project data or connect with other services. Agents select and use tools based on the task and context.
Model
Each Agent has an Generative AI model such as a large language model (LLM) that acts as its “brain.” It interprets instructions, reasons through problems, generates language, and coordinates other components to complete tasks.
Types
Chat Agents
The Tygron Platform currently has two default AI Chat Agents:
- WIKI Assistant: Searching the Tygron Wiki for information on features, configurations and guides.
- Project Coder: Can edit data in your Project, by executing TQL queries or interact with project API endpoints.
Design Agents
These agents are under development but can be used to generate and test new city layouts based on Parametric Designs. Using a Diffusion Model the Agent will generate a design that will be tested using specialized tools on it's score. This tool feedback is then used to further optimize the design in a new round.
Privacy
To protect your data, several measures have been takes. These are described in our AI Rules.
Interaction
You can interact with an AI Agents by using the Chat Panel in the editor.
