Api session event editor chat add message
Revision as of 07:23, 5 October 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorchat/add_message/ Description: Add a new Chat Message with optional Image or PDF content {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (CHAT_CHANNEL Integer ID) | Channel ID | |- | 1 | REQUIRED | (String) | Message | |- | 2 | OPTIONAL | (String) | Content Mime Type (optional) | |- | 3 | OPTIONAL | (byte or multiple values in array [a, b, c]) | Content bytes (optional) | |} ===Response C...")
0 REQUIRED (CHAT_CHANNEL Integer ID) Channel ID
1 REQUIRED (String) Message
2 OPTIONAL (String) Content Mime Type (optional)
3 OPTIONAL (byte or multiple values in array [a, b, c]) Content bytes (optional)
200 Integer (Returns the ID of the resulting response message.)
curl 'https://engine.tygron.com/api/session/event/editorchat/add_message/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Message" ]'
JavaScript example POST
 body: '[ 1, "Message" ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/add_message/", options)
