Excel Sheet
Excel Sheet is an Item that stores data of an Excel File.
Properties
An Excel Sheet items has the following properties:
  • Byte array of the Excel File contents
  • Name of the file.
  • Uploader name and date
  • Warnings from Calculation
  • Optional certification:
    • Certificate Author
    • Certificate Path
    • Certificate State: NONE, CERTIFIED, UNCERTIFIED
Calculation Instances
A single Excel Sheet can be referenced by multiple Panels and Indicators. Indicator and Panel calculators can fill their instance of an Excel Sheet with their specific TQL Queries. An example is of a specific TQL Query is: SELECT_NAME_WHERE_INDICATOR_IS_ID
  • The name of an Excel Sheet is limited to lowercase with underscores.
  • Contrary to its name, an Excel Sheet item can hold the contents of an Excel file with multiple sheets.
