Api session items specialeffects
API Endpoint: /api/session/items/specialeffects/
Edit items with events described at Api session event editor specialeffect.
Default Query:
https://engine.tygron.com/api/session/items/specialeffects/?token=API_TOKENExample Response:
[ ]Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/specialeffects/?version=100&token=API_TOKENGet Queries
Attributes:
https://engine.tygron.com/api/session/items/specialeffects/attributes/?token=API_TOKENMax version:
https://engine.tygron.com/api/session/items/specialeffects/version/?token=API_TOKENCount:
https://engine.tygron.com/api/session/items/specialeffects/count/?token=API_TOKENSpecific Item by ID:
https://engine.tygron.com/api/session/items/specialeffects/{id}/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/specialeffects/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/specialeffects/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/specialeffects/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/specialeffects/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/specialeffects/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/specialeffects/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/specialeffects/?f=ZIPSMILE&token=API_TOKENApi Model ParticleEmitterCoordinatePair
API Model description of ParticleEmitterCoordinatePair
| Name | Type | Description |
| id | int | |
| offsetCoordinate | double[] | |
| particleEmitterID | int | Particle Emitter ID |
Api Model Point
API Model description of Point
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
Api Model SpecialEffect
API Model description of SpecialEffect
| active | boolean | |
| id | int | |
| name | String | |
| particleEmitters | ParticleEmitterCoordinatePair[] | Particle EmitterCoordinatePair[] |
| point | Point | Point |
| version | int |
