Api session event editor skill add
Revision as of 13:31, 22 September 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorskill/add/ Description: Add a new AI Skill file Item {|class=wikitable !Index !Importance !Type !Description !Values |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | Integer (Returns the ID of new Skill file item.) |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight lang="text" copy>curl 'https://engine.tygron.com/api/session/event/editorskill/add/' -H 'Con...")
200 Integer (Returns the ID of new Skill file item.)
curl 'https://engine.tygron.com/api/session/event/editorskill/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorskill/add/", options)
