Api session query
API Base URL: api/session/query/
GET {query}
API Endpoint: api/session/query/{query}
Parameters:
| Name | Location | Type | Default value |
| query | Path | String | |
| value | Query | String | 0.0 |
| f | Query | Format | JSON |
| validate | Query | boolean | false |
| crs | Query | String | EPSG:3857 |
Examples
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_SOCIAL_AND_MAP_IS_MAQUETTE:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_SOCIAL_AND_MAP_IS_MAQUETTE?crs=3857&f=JSON&token=API_TOKENSELECT_FLOORSIZE_WHERE_CATEGORY_IS_EDUCATION_AND_MAP_IS_CURRENT:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_EDUCATION_AND_MAP_IS_CURRENT?crs=3857&f=HTML&token=API_TOKENSELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_CURRENT:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_CURRENT?crs=3857&f=JSON&token=API_TOKENSELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA?crs=3857&f=SMILE&token=API_TOKENSELECT_FLOORSIZE_WHERE_CATEGORY_IS_NORMAL_AND_MAP_IS_MAQUETTE:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NORMAL_AND_MAP_IS_MAQUETTE?crs=3857&f=ZIPJSON&token=API_TOKENSELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA?crs=3857&f=ZIPSMILE&token=API_TOKENSELECT_COLOR_WHERE_CATEGORY_IS_OTHER:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_OTHER?crs=3857&f=JSON&token=API_TOKENSELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL?crs=4326&f=JSON&token=API_TOKENSELECT_COLOR_WHERE_CATEGORY_IS_AGRICULTURE:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_AGRICULTURE?crs=28992&f=JSON&token=API_TOKENSELECT_NAME_WHERE_CATEGORY_IS_SENIOR:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_SENIOR?crs=LOCAL&f=JSON&token=API_TOKENPOST query
Content-Type: application/x-www-form-urlencoded
Parameters:
POST query
Content-Type: application/json
Parameters:
Examples
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query 1"'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TQL Query 1", "TQL Query 2", "TQL Query 3" ]'JavaScript example POST:
body: '"TQL Query 1"'
fetch("https://engine.tygron.com/api/session/query/", options)
.catch(error => console.log('error', error));GET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_SOCIAL_AND_MAP_IS_MAQUETTE
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_SOCIAL_AND_MAP_IS_MAQUETTE
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_SOCIAL_AND_MAP_IS_MAQUETTE?crs=3857&f=JSON&token=API_TOKENGET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_EDUCATION_AND_MAP_IS_CURRENT
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_EDUCATION_AND_MAP_IS_CURRENT
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_EDUCATION_AND_MAP_IS_CURRENT?crs=3857&f=HTML&token=API_TOKENGET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_CURRENT
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_CURRENT
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_CURRENT?crs=3857&f=JSON&token=API_TOKENGET SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA
API Endpoint: api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA?crs=3857&f=SMILE&token=API_TOKENGET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NORMAL_AND_MAP_IS_MAQUETTE
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NORMAL_AND_MAP_IS_MAQUETTE
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NORMAL_AND_MAP_IS_MAQUETTE?crs=3857&f=ZIPJSON&token=API_TOKENGET SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA?crs=3857&f=ZIPSMILE&token=API_TOKENGET SELECT_COLOR_WHERE_CATEGORY_IS_OTHER
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_OTHER
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_OTHER?crs=3857&f=JSON&token=API_TOKENGET SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL?crs=4326&f=JSON&token=API_TOKENGET SELECT_COLOR_WHERE_CATEGORY_IS_AGRICULTURE
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_AGRICULTURE
Parameters:
Examples
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_AGRICULTURE?crs=28992&f=JSON&token=API_TOKENGET SELECT_NAME_WHERE_CATEGORY_IS_SENIOR
API Endpoint: api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_SENIOR
Parameters:
Examples
