Api session items specialeffects
Revision as of 08:08, 22 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/specialeffects/
Edit items with events described at Api session event editor specialeffect.
Default Query:
https://engine.tygron.com/api/session/items/specialeffects/?token=API_TOKEN
Example Response:
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/specialeffects/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/specialeffects/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/specialeffects/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/specialeffects/count/?token=API_TOKEN
Specific Item:
https://engine.tygron.com/api/session/items/specialeffects/{itemID}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/specialeffects/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/specialeffects/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/specialeffects/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/specialeffects/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/specialeffects/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/specialeffects/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/specialeffects/?f=ZIPSMILE&token=API_TOKEN
Api Model ParticleEmitterCoordinatePair
API Model description of ParticleEmitterCoordinatePair
Name Type Description
id int
offsetCoordinate double[]
particleEmitterID int Particle Emitter ID
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model SpecialEffect
API Model description of SpecialEffect
active boolean
id int
name String
particleEmitters ParticleEmitterCoordinatePair[] Particle EmitterCoordinatePair[]
point Point Point
version int
