Api session query
Revision as of 07:39, 22 September 2026 by Frank@tygron.nl (talk | contribs)
API Base URL: api/session/query/
GET {query}
API Endpoint: api/session/query/{query}
Parameters:
Name Location Type Default value
query Path String
value Query String 0.0
f Query Format JSON
validate Query boolean false
crs Query String EPSG:3857
Examples
SELECT_NAME_WHERE_CATEGORY_IS_SENIOR:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_SENIOR?crs=3857&f=JSON&token=API_TOKEN
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_INDUSTRY_AND_MAP_IS_MAQUETTE:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_INDUSTRY_AND_MAP_IS_MAQUETTE?crs=3857&f=HTML&token=API_TOKEN
SELECT_COLOR_WHERE_CATEGORY_IS_GARDEN:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_GARDEN?crs=3857&f=JSON&token=API_TOKEN
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_MAQUETTE:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_MAQUETTE?crs=3857&f=SMILE&token=API_TOKEN
SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL?crs=3857&f=ZIPJSON&token=API_TOKEN
SELECT_NAME_WHERE_CATEGORY_IS_LUXE:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_LUXE?crs=3857&f=ZIPSMILE&token=API_TOKEN
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_AGRICULTURE_AND_MAP_IS_CURRENT:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_AGRICULTURE_AND_MAP_IS_CURRENT?crs=3857&f=JSON&token=API_TOKEN
SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA?crs=4326&f=JSON&token=API_TOKEN
SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA?crs=28992&f=JSON&token=API_TOKEN
SELECT_NAME_WHERE_CATEGORY_IS_LEISURE:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_LEISURE?crs=LOCAL&f=JSON&token=API_TOKEN
POST query
Content-Type: application/x-www-form-urlencoded
Parameters:
f Query Format JSON
POST query
Content-Type: application/json
Parameters:
f Query Format JSON
Examples
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query 1"'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TQL Query 1", "TQL Query 2", "TQL Query 3" ]'
JavaScript example POST:
 body: '"TQL Query 1"'
fetch("https://engine.tygron.com/api/session/query/", options)
GET SELECT_NAME_WHERE_CATEGORY_IS_SENIOR
API Endpoint: api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_SENIOR
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_INDUSTRY_AND_MAP_IS_MAQUETTE
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_INDUSTRY_AND_MAP_IS_MAQUETTE
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_COLOR_WHERE_CATEGORY_IS_GARDEN
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_GARDEN
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_MAQUETTE
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_NATURE_AND_MAP_IS_MAQUETTE
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_SOCIAL
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_NAME_WHERE_CATEGORY_IS_LUXE
API Endpoint: api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_LUXE
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_AGRICULTURE_AND_MAP_IS_CURRENT
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_AGRICULTURE_AND_MAP_IS_CURRENT
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_PAVED_AREA
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA
API Endpoint: api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA
Parameters:
query Path String
f Query Format JSON
Examples
GET SELECT_NAME_WHERE_CATEGORY_IS_LEISURE
API Endpoint: api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_LEISURE
Parameters:
query Path String
f Query Format JSON
Examples
