Api session items geoplugins
API Endpoint: /api/session/items/geoplugins/
Edit items with events described at Api session event editor geoplugin.
Default Query:
https://engine.tygron.com/api/session/items/geoplugins/?f=JSON&token=API_TOKENExample Response:
"crs" : "urn:ogc:def:crs:EPSG::28992",
"forceXY" : true,
"geoLinkIDs" : [ 2264, 2265, 2266, 2267 ],
"id" : 0,
"idAttribute" : "nr",
"layerName" : "natura2000:natura2000",
"linkType" : "AREA",
"name" : "Natura2000",
"nameAttribute" : "naam_n2k",
"newProject" : false,
"sourceID" : 103,
"version" : 1
"crs" : "",
"forceXY" : true,
"geoLinkIDs" : [ 1000259, 1000260 ],
"id" : 1000000,
"idAttribute" : "",
"layerName" : "",
"linkType" : "BUILDING",
"name" : "Building Geo Plugin",
"nameAttribute" : "",
"newProject" : true,
"sourceID" : -1,
"version" : 2
} ]Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/geoplugins/?version=100&token=API_TOKENGet Queries
Attributes:
https://engine.tygron.com/api/session/items/geoplugins/attributes/?token=API_TOKENMax version:
https://engine.tygron.com/api/session/items/geoplugins/version/?token=API_TOKENCount:
https://engine.tygron.com/api/session/items/geoplugins/count/?token=API_TOKENSpecific Item:
https://engine.tygron.com/api/session/items/geoplugins/{itemID}/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/geoplugins/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/geoplugins/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/geoplugins/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/geoplugins/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/geoplugins/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/geoplugins/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/geoplugins/?f=ZIPSMILE&token=API_TOKENApi Model AbstractGeoPlugin
API Model description of AbstractGeoPlugin
| Name | Type | Description |
| crs | String | |
| forceXY | boolean | |
| id | int | |
| linkType | GeoLinkType | Geo LinkType |
| name | String | |
| newProject | boolean | |
| version | int |
Api Model GeoLinkType
API Enumeration description of GeoLinkType
| Name | Description |
| AREA | |
| BUILDING | |
| ROAD | |
| TERRAIN_HEIGHT | |
| WATER_BOTTOM | |
| STREET_OBJECT |
Api Model GeoPlugin
API Model description of GeoPlugin
| crs | String | |
| geoLinkIDs | int[] | Geo Links ID |
| id | int | |
| idAttribute | String | |
| layerName | String | |
| name | String | |
| nameAttribute | String | |
| sourceID | int | Source ID |
| version | int |
Api Model HeightPlugin
API Model description of HeightPlugin
| crs | String | |
| id | int | |
| name | String | |
| sourceIDs | int[] | Sources ID |
| version | int |
