Api session items actionlogs
API Endpoint: /api/session/items/actionlogs/
Default Query:
https://engine.tygron.com/api/session/items/actionlogs/?f=JSON&token=API_TOKENExample Response:
[ ]Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/actionlogs/?version=100&token=API_TOKENGet Queries
Attributes:
https://engine.tygron.com/api/session/items/actionlogs/attributes/?token=API_TOKENMax version:
https://engine.tygron.com/api/session/items/actionlogs/version/?token=API_TOKENCount:
https://engine.tygron.com/api/session/items/actionlogs/count/?token=API_TOKENSpecific Item:
https://engine.tygron.com/api/session/items/actionlogs/{itemID}/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/actionlogs/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/actionlogs/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/actionlogs/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/actionlogs/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/actionlogs/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/actionlogs/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/actionlogs/?f=ZIPSMILE&token=API_TOKENApi Model ActionLog
API Model description of ActionLog
| Name | Type | Description |
| action | ParticipantEventType | |
| budget | double | |
| buildingIDs | int[] | |
| id | int | |
| itemID | int | |
| mapLink | MapLink | Maplink |
| mp | MultiPolygon | MultiPolygon |
| point | Point | Point |
| scoreAfter | Map<int,double> | |
| scoreBefore | Map<int,double> | |
| simTime | long | |
| stakeholderID | int | Stakeholder ID |
| subject | String | |
| version | int |
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model Point
API Model description of Point
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
